Tlr Posted April 20, 2023 Share Posted April 20, 2023 The mouse arrow appears on the screeen and moves very well however anyone know how to scroll up and down with the BT250? Quote Link to comment Share on other sites More sharing options...
dishuser Posted April 20, 2023 Share Posted April 20, 2023 hold the ok button Quote Link to comment Share on other sites More sharing options...
Tlr Posted April 20, 2023 Author Share Posted April 20, 2023 Tried that and it doesn't not work.... perhaps I need to repair the remote? Quote Link to comment Share on other sites More sharing options...
dishuser Posted April 20, 2023 Share Posted April 20, 2023 sorry I was thinking of the arq 250 if you are referring to scrolling for apps like netflix you can't Quote Link to comment Share on other sites More sharing options...
Tlr Posted April 20, 2023 Author Share Posted April 20, 2023 Thank you for the feedback. I just purchased the ARQ-200 and I like it better due to backlight and Querty keyboard. All is working well however I can't seem to put it into learning mode. Any suggestions as I have scoured this site and the internet and no luck... just about learning mode for the ARQ-100. Quote Link to comment Share on other sites More sharing options...
Emporium Posted April 20, 2023 Share Posted April 20, 2023 (edited) The ARQ200 does not have any "learning" mode. It is designed for the newer 5 series of BuzzTV boxes. And those have a menu, where you can program shirtcuts to the colored buttons. The rest are already hardcoded to BuzzTV code. The only learning is to be able to pair it with the USB dongle (should it not be pre-paired. The quick install guide can be found here: https://buzztv.com/wp-content/uploads/2023/04/BuzzTV-ARQ-200s-Remote-Manual-v3.pdf It is very similar to the generic MX3 type remotes, but the colored buttons are not IR learning. They work within the BuzzTV software, and can be programmed for program shortcuts when in anything else (on a 5 series Buzz box). Edited April 20, 2023 by Emporium Quote Link to comment Share on other sites More sharing options...
Tlr Posted April 20, 2023 Author Share Posted April 20, 2023 So how can you program the TV to power up at the same time as the BuzzTV? Quote Link to comment Share on other sites More sharing options...
Tlr Posted April 20, 2023 Author Share Posted April 20, 2023 MAybe turning on the Allow STB to power on and power off TV in the CEC settings? Quote Link to comment Share on other sites More sharing options...
Emporium Posted April 20, 2023 Share Posted April 20, 2023 12 minutes ago, Tlr said: MAybe turning on the Allow STB to power on and power off TV in the CEC settings? That's probably the only way. assuming your TV supports it. The remote was never advertised as having "learn IR" features. Quote Link to comment Share on other sites More sharing options...
dishuser Posted April 20, 2023 Share Posted April 20, 2023 13 minutes ago, Tlr said: MAybe turning on the Allow STB to power on and power off TV in the CEC settings? that should do it Quote Link to comment Share on other sites More sharing options...
