Need to do a Master/Factory reset
Mike Blickfeldt
The other embedded player.  From LiveTV, press Menu->Settings->configuration and on the top you will see the Video player options for LiveTV/VOD.  If you are on Primary, try Backup, or vice versa.
BTW: Are you connected via WiFi or Hardwired ?  "IF" possible, can you try hardwired, to eliminate the WiFi variable (which can be affected by a number of factors).
6 minutes ago, Mike Blickfeldt said:
Just switched to "backup" player.  It appears to be working better but I need to go to bed.  I'll report tomorrow.  Thanks for the help guys.  BTW: I am not able to hardwire at this time.
you could always get a powerline ethernet adapter kit
