Mark7 Posted April 9, 2023 Posted April 9, 2023 Does the Classic 5 have ARF settings? Keep getting a annoying Frame Rate Notification, and I would like to turn that Off, if possible. Thank you, Mark7 Â Quote
Ryu Posted April 9, 2023 Posted April 9, 2023 not sure if this will help you but maybe you can try this, go to settings, device preferences, display and sounds, screen resolution, and try to turn off auto switch to best resolution to see if this helps. Quote
