Nomorecable Posted February 3, 2021 Posted February 3, 2021 I have the xrs4500....I’ve been told by BuzzTV technician to record a program .....to download to an external hard drive (when I record directly to the box it does not work). when I playback the recording from the external hard drive ....there is an audio delay by about 7 seconds. Very frustrating.... how can I fix this delay? thank you Quote
nbs. Posted February 3, 2021 Posted February 3, 2021 What type of recording are you doing and what player are you using? 1 Quote
nbs. Posted February 3, 2021 Posted February 3, 2021 I also have no idea why you cant record to box either? Quote
allaboutbuzz Posted February 3, 2021 Posted February 3, 2021 2 hours ago, Nomorecable said: I have the xrs4500....I’ve been told by BuzzTV technician to record a program .....to download to an external hard drive (when I record directly to the box it does not work). when I playback the recording from the external hard drive ....there is an audio delay by about 7 seconds. Very frustrating.... how can I fix this delay? thank you If you playback the same recording using an external player like VLC or MX player do you get the same issue? Or if you take the Hard Drive and connect to a computer and try to play it from there, do you get the same issue? If so for either, then there was an issue with the stream when it was recorded. Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 18 hours ago, nbs. said: What type of recording are you doing and what player are you using? I’m recording a show using the BuzzTV xrs4500. I’m a newbie at this...don’t know what you mean by PLAYER. Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 16 hours ago, allaboutbuzz said: Or if you take the Hard Drive and connect to a computer and try to play it from there, do you get the same issue? I take the external hard drive and when I plug into my computer there’s nothing there but according to my BuzzTV it says it recording....it’s listed under my recordings when completed but when I play it nothing is there Quote
allaboutbuzz Posted February 4, 2021 Posted February 4, 2021 6 minutes ago, Nomorecable said: I take the external hard drive and when I plug into my computer there’s nothing there but according to my BuzzTV it says it recording....it’s listed under my recordings when completed but when I play it nothing is there Did you check the folders inside your Hard Drive It saves to Android/Media/buzzxr4000tv/recordings Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 (edited) 1 hour ago, Nomorecable said: I’m recording a show using the BuzzTV xrs4500. I’m a newbie at this...don’t know what you mean by PLAYER. There are media players under menu configuration player Are you doing scheduled recording or recording from guide? Edited February 4, 2021 by nbs. Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 2 hours ago, allaboutbuzz said: Did you check the folders inside your Hard Drive It saves to Android/Media/buzzxr4000tv/recordings Yes....not there Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 39 minutes ago, nbs. said: There are media players under menu configuration player Are you doing scheduled recording or recording from guide? Scheduled recording Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 You are leaving the buzz unit on? Did you find where the media players were? Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 2 hours ago, nbs. said: You are leaving the buzz unit on? Did you find where the media players were? Yes I leave it on..... I was able to find media players on the App Store but I was told when I playback the recording on any media player it won’t work if the box doesn’t record. as I mentioned earlier....it shows it recorded but when I playback there is nothing....I also tried to playback on my computer (I used an external hard drive to store) and it also tells me there is nothing Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 3 hours ago, nbs. said: There are media players under menu configuration player Are you doing scheduled recording or recording from guide? Sorry if this sounds ridiculous......Besides the App Store for media players...where do I find the menu configuration player Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 1 minute ago, Nomorecable said: Yes I leave it on..... I was able to find media players on the App Store but I was told when I playback the recording on any media player it won’t work if the box doesn’t record. as I mentioned earlier....it shows it recorded but when I playback there is nothing....I also tried to playback on my computer (I used an external hard drive to store) and it also tells me there is nothing when watching tv full screen hit the menu on remote.configuration.video player 1 Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 I also should ask if you formatted the drive Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 I just did two recordings one on default and one on secondary player the default is fine the secondary player is out of sync 1 Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 50 minutes ago, nbs. said: I just did two recordings one on default and one on secondary player the default is fine the secondary player is out of sync I tried recording a one hour show as I was watching it. Once it was over I went into pvr and it was listed under recordings and it WORKED when I selected it but there is an audio delay of about two seconds and the recording was done on SECONDARY I will try another show later on DEFAULT and see what happens.... but I hate to think I need to record as I watch it live.... Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 no, just make sure you are on default I have scheduled while recording from guide and manual scheduling many times no issues Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 1 hour ago, nbs. said: 5 minutes ago, nbs. said: no, just make sure you are on default I have scheduled while recording from guide and manual scheduling many times no issues From menu ....when I select default and the click back.....it automatically goes back to secondary Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 (edited) you hit ok and check the one you want Edited February 4, 2021 by nbs. Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 6 minutes ago, nbs. said: you hit ok and check the one you want Ok...switched to default.....I will record a show soon but I won’t be watching it as it’s recording....so I’ll see if it works and hopefully no audio delay buffer time was set at 3 seconds....will this affect the audio delay? Quote
nbs. Posted February 4, 2021 Posted February 4, 2021 never used or changed the buffer since i got the 4500 Quote
Nomorecable Posted February 4, 2021 Author Posted February 4, 2021 8 minutes ago, nbs. said: never used or changed the buffer since i got the 4500 Ok......I’ll let you know later how my next recording turns out Quote
Nomorecable Posted February 5, 2021 Author Posted February 5, 2021 2 hours ago, nbs. said: never used or changed the buffer since i got the 4500 So I preset the recording for another show....and I made sure by double checking a few times it was set to default. The recording worked but the audio is still delayed. ......I don’t get it Quote
Nomorecable Posted February 5, 2021 Author Posted February 5, 2021 2 hours ago, nbs. said: never used or changed the buffer since i got the 4500 Also forgot to mention......when I was watching the recorded show......for some reason it bounced to secondary from default. As I said.....I even checked a few times and made sure it was on default Quote
