scand-iptv.com Posted January 5, 2021 Share Posted January 5, 2021 Received my vidstick today and tried playing around with the color settings in the advanced menu. After changing the YCbCr settings, the videosignal is not recognized by the TV and I can't access it. Have tried reset via pin hole, but no luck. Any ideas? Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 5, 2021 Share Posted January 5, 2021 1 hour ago, scand-iptv.com said: Received my vidstick today and tried playing around with the color settings in the advanced menu. After changing the YCbCr settings, the videosignal is not recognized by the TV and I can't access it. Have tried reset via pin hole, but no luck. Any ideas? You have to put the pin in and hold it then power on stick and keep holding it until android recovery menu appears 1 Quote Link to comment Share on other sites More sharing options...
scand-iptv.com Posted January 5, 2021 Author Share Posted January 5, 2021 I have held it, put power in and kept holding it for up to one minute. Recovery menu does not appear. There is power to the stick as the light on the back is turned on Quote Link to comment Share on other sites More sharing options...
scand-iptv.com Posted January 5, 2021 Author Share Posted January 5, 2021 Solved, I had some strange HDR setting on the TV which f'ed up the signal. When turning it off the signal went through and recovery mode menu appeared. Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 5, 2021 Share Posted January 5, 2021 glad you figured it out Quote Link to comment Share on other sites More sharing options...
