On 1/2/2021 at 7:43 PM, JKA said:
I think I may have found a bug in the epg code that was not apparent to me prior to the update. Since the update, the epg duplicates the current channel info, and inserts it into the next available time slot. I tried it on every service I have, and it’s the same.
start on the left side of the epg and pick a show to watch. Now look on the right hand side below the Picture in Picture to upcoming shows. You will see the current show info being displayed at the starting time at the top.  You will then see the same info for the next time slot.
it’s not showing the right information.
hope this helps. Jim.
12 minutes ago, nbs. said:
I took a good  look at my epg and my epg is the same as JKA
If you look at the picture you will see news is on for two hours instead of being on at 6 only
Just checked myself
And also see it
But on Grid Guide/EPG its accurate.
8 minutes ago, allaboutbuzz said:
Just checked myself
And also see it
never noticed it until now because I always press guide button
I see this issue as well, any server.   Only on the "channel list -upcoming  shows " as noted.
Full grid guide EPG is fine, as is the "single channel guide" (right arrow ), and the "Next" that appears on screen when using Info button.
I made the same observations in relation to EPG and I conclude that we are in the presence of a bug in the programming of the display in this mode.  Unlike dishuser, I always use that mode with the wrong display.  It's rather unpleasant not to be able to see the next show on the channel being viewed.  Is it realistic to believe that this bug will be fixed in a future update or some patch?  From whom and by whom should this be requested? Does nbs. or allaboutbuzz can help us with matter?
Thanks in advance!
Thanks in advance!
He has already stated it will be fixed in next weeks update
  • 2 weeks later...
Epg works fine on the 4 services I know If you are referring to the double entry in quick guide it will be fixed soon
Edited by nbs.
22 hours ago, dishuser said:
when you press back button to exit quick guide it shows what program is next accurately
same as pressing info button
The issue of Channel List duplicating the EPG for whats on now and next + the no Sub Titles issue and few other issues
We fixed on an Internal Beta on Friday.
Anyone wanting to try it, can just PM me their Serial #
Thanks
  • Thanks 1
