Kroach2159 Posted December 12, 2020 Posted December 12, 2020 I cannot get my Buzz Tv switch over to Ethernet . I’ve tried cutting off the WiFi , nothing seems to affect it, I check Ethernet connection also. Any help will be appreciated. Thanks Quote
nbs. Posted December 12, 2020 Posted December 12, 2020 cutting off? did you turn off wifi in settings? maybe reboot try another ethernet cable Quote
Kroach2159 Posted December 12, 2020 Author Posted December 12, 2020 I never got it to come on, I have been using WiFi. Quote
nbs. Posted December 12, 2020 Posted December 12, 2020 you said "I tried cutting off the wifi: Does that mean you shut it off in settings? Quote
Kroach2159 Posted December 12, 2020 Author Posted December 12, 2020 I went to settings and cut off the wifi thinking that may help. But still when I go down to ETH it still does not connect Quote
nbs. Posted December 13, 2020 Posted December 13, 2020 does the light on the router where you plug it come on? Quote
Nelutz Posted December 13, 2020 Posted December 13, 2020 With me worked right away when I power of/on the box with the ethernet cable in ofcorse Quote
