ledfoot Posted November 20, 2020 Share Posted November 20, 2020 Hi have 2 XL3000 boxes and 1 XRS4000 box all connected to the same server and hard wired to my router. There are some channels that will not tune in on the XRS4000 but the load fine on the 3000. Is this something specific to my server or can something be done on the XRS4000 to correct this? I have tried using the secondary video player as well and this did not help. Quote Link to comment Share on other sites More sharing options...
Nelutz Posted November 20, 2020 Share Posted November 20, 2020 (edited) 25 minutes ago, ledfoot said: Hi have 2 XL3000 boxes and 1 XRS4000 box all connected to the same server and hard wired to my router. There are some channels that will not tune in on the XRS4000 but the load fine on the 3000. Is this something specific to my server or can something be done on the XRS4000 to correct this? I have tried using the secondary video player as well and this did not help. Hmm this is my first time when i see that someone has this problem ,and I've used all the Buzztv boxes ,to bad I don't have an xpl3000 anymore to see if is doing the same on my server ,that's so weird Edited November 20, 2020 by Nelutz None Quote Link to comment Share on other sites More sharing options...
dishuser Posted November 20, 2020 Share Posted November 20, 2020 3 hours ago, Nelutz said: Hmm this is my first time when i see that someone has this problem ,and I've used all the Buzztv boxes ,to bad I don't have an xpl3000 anymore to see if is doing the same on my server ,that's so weird they're not having issues with their 3000 Quote Link to comment Share on other sites More sharing options...
Nelutz Posted November 20, 2020 Share Posted November 20, 2020 2 hours ago, dishuser said: they're not having issues with their 3000 Yes I know, I was referring to the xpl3000 to do the same test he did to see if I have the same problem on my server, since I don't have one anymore I cant see if is from the server or from the xrs4000 which I have. Quote Link to comment Share on other sites More sharing options...
ledfoot Posted November 20, 2020 Author Share Posted November 20, 2020 Correct. I can view specific channels on my 3000 and at times they will not tune in on the 4000 but they will eventually come back. Quote Link to comment Share on other sites More sharing options...
nbs. Posted November 20, 2020 Share Posted November 20, 2020 Send allaboutbuzz a pm with some details Quote Link to comment Share on other sites More sharing options...
ledfoot Posted November 23, 2020 Author Share Posted November 23, 2020 OK, will do Quote Link to comment Share on other sites More sharing options...
Lantzco Posted December 13, 2020 Share Posted December 13, 2020 XRS 4000 my channel list doesn't load either Quote Link to comment Share on other sites More sharing options...
Kofison881 Posted January 3, 2021 Share Posted January 3, 2021 Hi, I own an S/N: BUZZTVB7201719 that doesn't turn on anymore; however, I can boot into factory service mode manually. The only problem that I am faced with is the firmware. I need firmware to install it on the box. If you could help me find the update, it'll be great. The edition is a 2018 model. Thanks Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 3, 2021 Share Posted January 3, 2021 1 minute ago, Kofison881 said: Hi, I own an S/N: BUZZTVB7201719 that doesn't turn on anymore; however, I can boot into factory service mode manually. The only problem that I am faced with is the firmware. I need firmware to install it on the box. If you could help me find the update, it'll be great. The edition is a 2018 model. Thanks you have a 4000? updates are only done ota Quote Link to comment Share on other sites More sharing options...
Kofison881 Posted January 3, 2021 Share Posted January 3, 2021 No, I have the discontinued XPL3000 version that still works but has no boot only manual factory service mod. Quote Link to comment Share on other sites More sharing options...
Kofison881 Posted January 3, 2021 Share Posted January 3, 2021 5 minutes ago, nbs. said: you have a 4000? updates are only done ota Is there a manual firmware update system on SD or a USB available? Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 3, 2021 Share Posted January 3, 2021 what box do you have? Quote Link to comment Share on other sites More sharing options...
Kofison881 Posted January 3, 2021 Share Posted January 3, 2021 1 minute ago, nbs. said: what box do you have? I have the discontinued XPL3000 version that still works but has no boot only manual factory service mod. Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 3, 2021 Share Posted January 3, 2021 did you do the pin reset and get the android menu? Quote Link to comment Share on other sites More sharing options...
Kofison881 Posted January 3, 2021 Share Posted January 3, 2021 3 minutes ago, nbs. said: did you do the pin reset and get the android menu? Yes, I did and it was successful however after factory resetting it never booted back it was stack in a dark screen. That's why a Firmware is necessary Quote Link to comment Share on other sites More sharing options...
nbs. Posted January 3, 2021 Share Posted January 3, 2021 (edited) 10 minutes ago, Kofison881 said: Yes, I did and it was successful however after factory resetting it never booted back it was stack in a dark screen. That's why a Firmware is necessary the firmware is not available Maybe try reset again? best to contact buzz cs@buzztv.com Edited January 3, 2021 by nbs. Quote Link to comment Share on other sites More sharing options...
Kofison881 Posted January 3, 2021 Share Posted January 3, 2021 Just now, nbs. said: the firmware is not available best to contact buzz cs@buzztv.com OK, I appreciate all the help. I'll contact them right away. Thanks Quote Link to comment Share on other sites More sharing options...
