Ryder Posted November 13, 2020 Posted November 13, 2020 I just bought this unit, and am finding that for a lot of the channels, the EPG will say one show is playing, but if I switch to that channel, something else is playing. This happens on multiple channels. What is very odd is that I have the exact same issue (although not as pronounced) on the EPG for my OTA box. The device is upto date (no updates available), and I see no way of setting where the guide is being downloaded from. This is very frustrating, and I am considering returning the device because of this issue along with other limitations I wasn't aware of when purchasing it - cannot watch one show while recording another, won't record if turned off, freezing (store blames this on my internet, but device is hooked up via ethernet and I have 150Mbps download, theoretically. Any advise on this would be appreciated, thank you. Quote
nbs. Posted November 13, 2020 Posted November 13, 2020 If your guide is off by a certain amount of time you can adjust it in menu configuration If the info is wrong that's a server issue There are no iptv boxes that you can record one channel and watch another Quote
Ryder Posted November 13, 2020 Author Posted November 13, 2020 So if it's a "server problem" how do I get it fixed? It is definitely a server issue not a time issue, sa some channels are correct, and others are not thank you Quote
nbs. Posted November 13, 2020 Posted November 13, 2020 3 hours ago, Ryder said: So if it's a "server problem" how do I get it fixed? It is definitely a server issue not a time issue, sa some channels are correct, and others are not thank you Contact whoever you bought off and complain Quote
allaboutbuzz Posted November 14, 2020 Posted November 14, 2020 This normally happens everything we have Daylight Savings Time So just complain or wait till they fix it. Quote
