mopar.man Posted September 8, 2020 Share Posted September 8, 2020 I seem to cut the recording off half way through , I can't seem to find any instructions any where on how to use pvr can you help? Thks James Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 8, 2020 Share Posted September 8, 2020 are you using scheduled? Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted September 9, 2020 Share Posted September 9, 2020 On 9/7/2020 at 10:43 PM, mopar.man said: I seem to cut the recording off half way through , I can't seem to find any instructions any where on how to use pvr can you help? Thks James What are you recording to, USB, SD Card or internal storage? If its USB or SD Card, sometimes users have these formatted to FAT32 Which cannot create files larger then 2GB 2GB would be about 1-2 hours worth of recording, depending on the channel quality It is suggested that your USB or SD Cards are formatted to NTFS for recordings. 1 2 Quote Link to comment Share on other sites More sharing options...
