spudnuts Posted July 19, 2020 Share Posted July 19, 2020 Not having many issues but would it be possible to have an option to change audio sync in a future update? I've seen it on other apps and works well and quite a handy feature to have. Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 19, 2020 Share Posted July 19, 2020 Have you tried both players? Quote Link to comment Share on other sites More sharing options...
spudnuts Posted July 19, 2020 Author Share Posted July 19, 2020 Yes I have like I say its not a massive issue just sometimes you get a feed that's slightly out of sync and option to change sync would be good. Just a suggestion for future updates not a fault with the player or box. Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 19, 2020 Share Posted July 19, 2020 I have found anytime I have an audio sync issue a reboot fixes it. Quote Link to comment Share on other sites More sharing options...
Nelutz Posted July 21, 2020 Share Posted July 21, 2020 I think is from the server too, happened with me today with one of the channels but when I went to the HD section the same channel had no sync problem. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted July 22, 2020 Share Posted July 22, 2020 On 7/19/2020 at 7:35 AM, spudnuts said: Not having many issues but would it be possible to have an option to change audio sync in a future update? I've seen it on other apps and works well and quite a handy feature to have. Will look into this and see if we can add it to a future update. 2 Quote Link to comment Share on other sites More sharing options...
