kielbear Posted June 18, 2020 Share Posted June 18, 2020 Is there any chance of an update to speed up the changing of subtitles? It´s annoying to have to press a button on the remote x amount of times to get to the subtitles you want and if you press to long it might skip past waht you want then you have to restart the process.. Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 18, 2020 Share Posted June 18, 2020 Are you referring to live tv? Whst buttons are you pressing and what do you mean the subtitles you want? I just hit the left arrow next to ok button and select Quote Link to comment Share on other sites More sharing options...
kielbear Posted June 19, 2020 Author Share Posted June 19, 2020 (edited) Thanks for the reply nbs.. when i watch vod.. and i want to change the subtiltes i can press the green button that brings up the closed caption choices.. it then shows on the screen eg. closed captioning track 6 Russian then i have to keep pressing the green button that shows then track 7 Swedish then 8 then 9 etc etc until you get to whatever subtitle you require.. when watching vod i can hit a button and the menue choices appear at the bottom.. on the left hand side it says scroll with arrows for left and right but this either fast forwards or backward.. its annoying when you press a moment to long then the closed captioning scrolls thro 4 or 5 tracks past what you want.. i dont have an option to just hit the left arrow to change subtitles Edited June 19, 2020 by kielbear Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 19, 2020 Share Posted June 19, 2020 (edited) I am not sure if the mate is getting the same update as the buzz 4000 and 4500 Allaboutbuzz can confirm if it is If it is getting an update you wont have that issue Edited June 19, 2020 by nbs. 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 20, 2020 Share Posted June 20, 2020 doesn't the mate use buzztv 2? Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 20, 2020 Share Posted June 20, 2020 yea it does ,just checked wws Quote Link to comment Share on other sites More sharing options...
kielbear Posted June 22, 2020 Author Share Posted June 22, 2020 On 6/20/2020 at 4:02 AM, dishuser said: doesn't the mate use buzztv 2? On 6/20/2020 at 4:33 AM, nbs. said: yea it does ,just checked wws Buzztv 2 .. does it still receive updates ? Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 22, 2020 Share Posted June 22, 2020 Yes 5 hours ago, kielbear said: Buzztv 2 .. does it still receive updates ? Yes but it wont get the update I was thinking of What version of buzz 2 are you on? Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 22, 2020 Share Posted June 22, 2020 Can you take apic of the subtitle screen and upload it? Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 22, 2020 Share Posted June 22, 2020 I have set up a box with buzz 2 software on it and I see the menus you are talking about I tap the green button until i get to the one I want and stop at the one i want I dont see how it can scroll past the one you want?? I dont think the sw would be any different Quote Link to comment Share on other sites More sharing options...
kielbear Posted June 22, 2020 Author Share Posted June 22, 2020 I bought a and sold a lot of Mate1 boxes.. 2 major complaints.. 1 the subtitles.. its easy to scroll past if you hold the button longer.. it´s annoying if you watch a lot of films with multi subtitles.. always having to pressing the button.. 2 again in vod when watching a film is changing the screen format.. if it´s 16:9 or something else and you want to change it.. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted June 22, 2020 Share Posted June 22, 2020 2 minutes ago, kielbear said: I bought a and sold a lot of Mate1 boxes.. 2 major complaints.. 1 the subtitles.. its easy to scroll past if you hold the button longer.. it´s annoying if you watch a lot of films with multi subtitles.. always having to pressing the button.. 2 again in vod when watching a film is changing the screen format.. if it´s 16:9 or something else and you want to change it.. Will take these suggestions into consideration And see if we can add the 4000 style menu for Sub Titles + Screen Size + Audio tracks to the Mate 1. I know what you mean by it being annoying. 1 Quote Link to comment Share on other sites More sharing options...
