Vod downloads fail
john smith
I try recording Vod movie and it works as long as it’s not longer then 4.29 gb   It will record up to that point then fails. Happens on my 4900 and my vid max. I have plenty of storage and set it up properly as it will record movie if it’s less than 4.29 gb long. Anyway would appreciate any help in this matter.
If you have formatted your media as FAT32, then the max file size is 4GB.  So that "may" be the limitation you are experiencing.
You would probably be better off putting your drive onto a PC, and formatting it as exFAT which does not have that single file size limitation.
Have you tried temporarily (as a test) trying to save it to the internal storage ?
