Benfica Posted June 8, 2020 Share Posted June 8, 2020 Hello guys...i see these 2 remotes ( IR-100L - Luminous Remote & ARQ-100 ) work with buzztv xrs 4500, from them wich would u recomend and do all keys work with them ? Quote Link to comment Share on other sites More sharing options...
mr man Posted June 8, 2020 Share Posted June 8, 2020 ARQ-100 1 Quote Link to comment Share on other sites More sharing options...
Mark Posted June 8, 2020 Share Posted June 8, 2020 The first remote comes with it. Second one is updated model you can purchase. I have ordered the second one due to the fact it has the built in keyboard. 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 8, 2020 Share Posted June 8, 2020 19 minutes ago, Mark said: The first remote comes with it. Second one is updated model you can purchase. I have ordered the second one due to the fact it has the built in keyboard. Unless things have changed the 4500 is still being advertised as coming with the bt-100 not the ir-100l 1 Quote Link to comment Share on other sites More sharing options...
Mark Posted June 9, 2020 Share Posted June 9, 2020 Your absolutely right. My apologies. 1 1 Quote Link to comment Share on other sites More sharing options...
Benfica Posted June 10, 2020 Author Share Posted June 10, 2020 So u guys mean either one all the keys will work ? like if u hit LiveTv will take u to livetv or hit Vod will go to Vod ? Quote Link to comment Share on other sites More sharing options...
Nelutz Posted June 10, 2020 Share Posted June 10, 2020 2 hours ago, Benfica said: So u guys mean either one all the keys will work ? like if u hit LiveTv will take u to livetv or hit Vod will go to Vod ? Yes will work ,right now I'm using 3 ARQ-100 and they work better than any remote so go ahead and get it , you will not regret it 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 10, 2020 Share Posted June 10, 2020 13 hours ago, Benfica said: So u guys mean either one all the keys will work ? like if u hit LiveTv will take u to livetv or hit Vod will go to Vod ? I have both and for the most part the arq-100 works THere are a couple of functios on the remote that dont work for me but i caan use the kb The il works great too Quote Link to comment Share on other sites More sharing options...
Benfica Posted June 13, 2020 Author Share Posted June 13, 2020 Guys...just got my Xrs4500 !! And wow, ive been a Mag user for many years , good box also but my Buzz is great, my reply to the topic is because i wont be in need of purchasing a remote ( for now ) because the one the box brought works real good ! May u all have a great weekend !! 1 Quote Link to comment Share on other sites More sharing options...
