StepBro Posted October 7, 2022 Posted October 7, 2022 I was wondering if there is a way or some app to install to make my Audio louder, live tv, streaming apps are all very very quiet , at 100 on my tv makes is some what usable, I connected to my sound bar with same results. My Jellyfin app however is loud at 25 on my tv. Wondering what the issues could be. Any help appreciated. Quote
dishuser Posted October 7, 2022 Posted October 7, 2022 the box doesn't output the audio like other models did you do auto tv setup in the app? Quote
Emporium Posted October 7, 2022 Posted October 7, 2022 I have my U5, X5, HD5 and my older xrs4500 connected to a 27" HP computer monitor via HDMI, and I have a pair of Bose sound companion 2 speakers connected to the Audio out from the monitor (which just takes the audio from the HDMI and outputs it over a standard 1/8" audio jack), and I have not noticed any difference in terms of volume loudness between any of the boxes (at least not with the 2 servers I use and one custom M3U list of live streams). Quote
dishuser Posted October 7, 2022 Posted October 7, 2022 55 minutes ago, Emporium said: I have my U5, X5, HD5 and my older xrs4500 connected to a 27" HP computer monitor via HDMI, and I have a pair of Bose sound companion 2 speakers connected to the Audio out from the monitor (which just takes the audio from the HDMI and outputs it over a standard 1/8" audio jack), and I have not noticed any difference in terms of volume loudness between any of the boxes (at least not with the 2 servers I use and one custom M3U list of live streams). on my 4900 and older models I have tv set at 60% all the newer models the volume is controlled by the source so anywhere between 15% to 20% Quote
allaboutbuzz Posted October 7, 2022 Posted October 7, 2022 13 hours ago, StepBro said: I was wondering if there is a way or some app to install to make my Audio louder, live tv, streaming apps are all very very quiet , at 100 on my tv makes is some what usable, I connected to my sound bar with same results. My Jellyfin app however is loud at 25 on my tv. Wondering what the issues could be. Any help appreciated. If you're using Source Pair on the Remote for Power Button Then do this From the Home Screen Go to Settings Go to Buzz Utilities Go to Volume Control Turn on Force Max Volume. See if that fixes your issues 1 Quote
StepBro Posted October 8, 2022 Author Posted October 8, 2022 Got it, thanks guy. The force max volume turns off after reset sometimes so I have to go in and re enable. Quote
