Orion1309 Posted May 30, 2020 Posted May 30, 2020 My vidstick st 4000 remote is freezing up on any function I use apks menu area sometimes it stops but starts right back up after a few secs Quote
nbs. Posted May 30, 2020 Posted May 30, 2020 I had a few issues at the start I unplugged stick for a few minutes then plugged back in and then it was ok Quote
Orion1309 Posted May 31, 2020 Author Posted May 31, 2020 I think I got it to work right now i just took off the Infrared cable that came in the box and just used the Bluetooth thats built-in the stick works fine now Quote
972deon Posted June 1, 2020 Posted June 1, 2020 Hello while using my IPTV services on the Buzz TV Vidstick all of a sudden it gets blocked in which I believe the issue is that The Buzztv 4 app is send too many request to my service therefore causing it to disable. Quote
allaboutbuzz Posted June 1, 2020 Posted June 1, 2020 1 hour ago, 972deon said: Hello while using my IPTV services on the Buzz TV Vidstick all of a sudden it gets blocked in which I believe the issue is that The Buzztv 4 app is send too many request to my service therefore causing it to disable. I PM you But you keep replying to my PM as reported content I can't reply properly to these In the top left of the Forum you will see an icon that looks like a message Click on this to access your PMs Thanks Quote
972deon Posted June 1, 2020 Posted June 1, 2020 LOL sorry about that and the option for fast loading epg is turned off Quote
Carmen Posted June 14, 2020 Posted June 14, 2020 My vidstick remote if frozen. Unplugging buzz tv does nothing. I’m stuck on the login page for thr Smarters app. Help! Quote
nbs. Posted June 14, 2020 Posted June 14, 2020 Just to clarify you are disconnecting power from unit and not just simply unplugging? Quote
Juggernaut Posted June 17, 2020 Posted June 17, 2020 On 6/1/2020 at 4:39 PM, 972deon said: Hello while using my IPTV services on the Buzz TV Vidstick all of a sudden it gets blocked in which I believe the issue is that The Buzztv 4 app is send too many request to my service therefore causing it to disable. Same thing happened to me with 2 of .y services I was wondering what was the issue with that Quote
