Johnny Posted September 29, 2022 Posted September 29, 2022 Hi I have an issue and I’m wondering if anyone has a fix to it. So basically I think my ISP is blocking the main service I use from working for me at certain times. For the first month from when I bought the service this would never happen and now it is just beginning to happen very frequently. So I got a VPN to see if it would fix the issue and it hasn’t. This isn’t a provider issue because earlier this summer when I was with another provider this same issue was happening. And even then it worked smoothly when I first bought it then the same thing started happening like a month or so after I got the service. So I’m just wondering does anybody have any solutions that might help me out. Thanks in advance. Quote
Ryu Posted September 29, 2022 Posted September 29, 2022 maybe someone using your credential. contact your iptv provider and ask them to change your credentials or lock your service with your ISP/region..etc if possible. Quote
