Drumcrazd Posted September 27, 2022 Posted September 27, 2022 I'm trying to record with this box and no matter which way I do it the recording always stops before the end....very frustrating......I'm using a 32 GB stick.....has anyone been successful here at recording?.......am I missing something here?.......any help would be appreciated.........thanks Quote
dishuser Posted September 27, 2022 Posted September 27, 2022 (edited) 28 minutes ago, Drumcrazd said: I'm trying to record with this box and no matter which way I do it the recording always stops before the end....very frustrating......I'm using a 32 GB stick.....has anyone been successful here at recording?.......am I missing something here?.......any help would be appreciated.........thanks how close to the end? are you adding extra recording time? Edited September 27, 2022 by dishuser Quote
Drumcrazd Posted September 27, 2022 Author Posted September 27, 2022 it's all over the place.....sometimes only records 20 min of a 2 hour recording.....sometimes records1 3/4 of a 2 hour program Quote
nbs. Posted September 27, 2022 Posted September 27, 2022 1 hour ago, Drumcrazd said: it's all over the place.....sometimes only records 20 min of a 2 hour recording.....sometimes records1 3/4 of a 2 hour program You on buzz 4 or 5? 1 Quote
dishuser Posted September 27, 2022 Posted September 27, 2022 I thought only android 9 or higher could get buzz5? 2 Quote
Emporium Posted September 27, 2022 Posted September 27, 2022 If I remember correctly, don't think the E1 had the required performance to run Buzz5 (I could be wrong). 1 Quote
Drumcrazd Posted September 27, 2022 Author Posted September 27, 2022 I don't even know what buzz5 is...lol.....I'm new.....are you talking about providers? Quote
Drumcrazd Posted September 27, 2022 Author Posted September 27, 2022 So I just tried formatting my stick to NFTS and tried recording "The Batman" movie.....I got an hour and a half before it quit recording and then subsequently locked up my box Quote
dishuser Posted September 27, 2022 Posted September 27, 2022 2 minutes ago, Drumcrazd said: I don't even know what buzz5 is...lol.....I'm new.....are you talking about providers? the builtin app Quote
Drumcrazd Posted September 27, 2022 Author Posted September 27, 2022 So are there any boxes Buzz make that can actually record for 2 or 3 hours without issues?? Quote
nbs. Posted September 27, 2022 Posted September 27, 2022 I can record with my 3900,4500 4900 Currently testing x5 and u5 1 Quote
dishuser Posted September 27, 2022 Posted September 27, 2022 (edited) 27 minutes ago, Drumcrazd said: So are there any boxes Buzz make that can actually record for 2 or 3 hours without issues?? press menu button what version shows at the bottom? also if you go to update screen it will show you firmware and software versions Edited September 27, 2022 by dishuser Quote
Drumcrazd Posted September 28, 2022 Author Posted September 28, 2022 On this box the version is: 4.0.519 Quote
Rinny1 Posted October 10, 2022 Posted October 10, 2022 Would be nice if an update for the buzz 4 app to clean up bugs Quote
