Buzz TV XR 4000 max size for the Micro SD Card
TheGhost
So I know the Buzz TV XR 4000 comes with a Micro SD Card slot on it
and I found other articles mentioning this as well
https://blog.iptvinsider.com/buzztv-xr-4000-iptv-box-review/
"AV, HDMI, 3.0 USB, 2.0 USB, Micro TF/SD Card option"
But what i don't know is since the Buzz TV XR 4000 is running off
of Android 9 what is the max size that this card can be is?
How big of a Micro SD Card can you put in these I wanted to
know before I got anything.
'Now is this slot a  MicroSDHC (High Capacity)?  or
MicroSDXC (extended Capacity) what exactly is it on this
device?
If it is a TF  like this person is saying in that article the transflash
AKA Micro SD  card slot then how big can I go?
If it is only am older SD card then I am reading that it only has a capacity
of up to 2 GB then. That isn't that much space really when it comes to
recording videos on the PVR that would get eaten up fast.
https://www.gearbest.com/blog/new-gear/tf-card-vs-sd-card-what-is-it-and-9-easy-ways-to-help-you-tell-their-differences-6305
Can one of the developers please let me know what the exact
spec is on that SD micro card slot please.
The other question is how do you get the PVR To now record to
that card as well automatically I believe I read some where
it is now possible with Buzz 5 which I have right now.
Thanks,
