Avenger Posted May 20, 2020 Share Posted May 20, 2020 Every once in a while, some fonction stop responding, need to remove battery, plug it back and it work again, just wondering is this a software issue or physical problem, i'm using buzz xr4000, one of my friend having the same setup, buzz xr4000 and arq100 and he just mention to me yesterday that it happen sometimes, that is remote stop responding, i know there was a issue with the xpl3000, just wondering if it the same for xr4000 Quote Link to comment Share on other sites More sharing options...
nbs. Posted May 20, 2020 Share Posted May 20, 2020 Quote Link to comment Share on other sites More sharing options...
Avenger Posted May 20, 2020 Author Share Posted May 20, 2020 Sorry i didn't know the usb dongle was actually a bluetooth transmitter, i tought the usb dongle was a wifi transmitter , like the mini usb dongle that came with a wireless mouse, actually the link you send mention after 3 second the remote resync and work Normally, but i could wait an eternity when it stop, it stop, there nothing i can do except remove battery and put it back. If the arq100 is actually a bluetooth like the link you send, how can i pair it with the bluetooth of the buzz xr4000 without the usb dongle, because i try the ok + vod on the remote when the pairing is searching device on the buzz and no remote found during the process. So in case you have another solution, let me know. Thx Quote Link to comment Share on other sites More sharing options...
nbs. Posted May 20, 2020 Share Posted May 20, 2020 Sorry I sent you wrong info Quote Link to comment Share on other sites More sharing options...
Mark Posted June 16, 2020 Share Posted June 16, 2020 (edited) I'm having same issue with ARQ-100 and the XRS-4500. Buttons just stop responding. I too have to remove a battery and it's ok after that. Pretty sure this remote is wifi. Edited June 16, 2020 by Mark Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 16, 2020 Share Posted June 16, 2020 What did you do with the remote that came with your xrs? Quote Link to comment Share on other sites More sharing options...
Nelutz Posted June 17, 2020 Share Posted June 17, 2020 (edited) On 5/19/2020 at 8:58 PM, Avenger said: Every once in a while, some fonction stop responding, need to remove battery, plug it back and it work again, just wondering is this a software issue or physical problem, i'm using buzz xr4000, one of my friend having the same setup, buzz xr4000 and arq100 and he just mention to me yesterday that it happen sometimes, that is remote stop responding, i know there was a issue with the xpl3000, just wondering if it the same for xr4000 Unplug and plug back the usb adapter-dongle u don't need to remove any battery. Edited June 17, 2020 by Nelutz Quote Link to comment Share on other sites More sharing options...
G2P Posted June 17, 2020 Share Posted June 17, 2020 On 5/19/2020 at 7:58 PM, Avenger said: Every once in a while, some fonction stop responding, need to remove battery, plug it back and it work again, just wondering is this a software issue or physical problem, i'm using buzz xr4000, one of my friend having the same setup, buzz xr4000 and arq100 and he just mention to me yesterday that it happen sometimes, that is remote stop responding, i know there was a issue with the xpl3000, just wondering if it the same for xr4000 I have the same problem with my XRS4000 and ARQ100 from last few weeks,and is going worst Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 17, 2020 Share Posted June 17, 2020 46 minutes ago, G2P said: I have the same problem with my XRS4000 and ARQ100 from last few weeks,and is going worst Are both batteries fully charged? Quote Link to comment Share on other sites More sharing options...
Nelutz Posted June 17, 2020 Share Posted June 17, 2020 7 hours ago, G2P said: I have the same problem with my XRS4000 and ARQ100 from last few weeks,and is going Try to switch to the other usb ,mine was giving me some problems when I was connecting the dongle to the blue color usb, or maybe you dropped or someone dropped the remote and from there the problems start, just trying different scenarios . Quote Link to comment Share on other sites More sharing options...
G2P Posted June 18, 2020 Share Posted June 18, 2020 Yes , both batteries are new and fully charged I will try with other USB port and let you know Thanks Quote Link to comment Share on other sites More sharing options...
G2P Posted June 20, 2020 Share Posted June 20, 2020 On 6/18/2020 at 9:15 AM, G2P said: Yes , both batteries are new and fully charged I will try with other USB port and let you know Thanks works ok now, have not changed port , but removed USB drive from another port, Also updated to newer Firmware so, not sure that Update solved the problem or another USB port removed usb drive. 1 Quote Link to comment Share on other sites More sharing options...
Nelutz Posted June 22, 2020 Share Posted June 22, 2020 On 6/20/2020 at 6:39 PM, G2P said: works ok now, have not changed port , but removed USB drive from another port, Also updated to newer Firmware so, not sure that Update solved the problem or another USB port removed usb drive. Remember if u have problems with the remote after you restarting the box ,just Unplug for 2-3sec the usb dongle and plug it back ,the remote will work properly. 1 Quote Link to comment Share on other sites More sharing options...
