sea157 Posted September 20, 2022 Posted September 20, 2022 Does anyone know if the BT-100 or BT-200 remote will work with the U5 box? The BT-400 will not work the way I need it to (don't want it to control the TV on & off). I am using the IR-200 remote to control the U5 right now and it operates the way I need it to, but the IR-200 remote is not backlite, I would like to get a backlite remote. Quote
gig63 Posted September 20, 2022 Posted September 20, 2022 Should work just fine just make sure you connect it to blue tooth I would use the BT 200 it's a lot nicer remote 1 Quote
Emporium Posted September 20, 2022 Posted September 20, 2022 I just paired my BT100 and it works perfectly fine also with the U5. 1 Quote
sea157 Posted September 20, 2022 Author Posted September 20, 2022 Thanks Guys! Now off to buy a BT-100 or BT-200! Quote
nbs. Posted September 20, 2022 Posted September 20, 2022 (edited) The bt200 is backlit Edited September 20, 2022 by nbs. 2 Quote
dishuser Posted September 20, 2022 Posted September 20, 2022 31 minutes ago, nbs. said: The bt200 is backlit so is the bt-100 2 Quote
Emporium Posted September 20, 2022 Posted September 20, 2022 BT200 also has TV volume control buttons So 2 extra programmable buttons. Quote
dishuser Posted September 21, 2022 Posted September 21, 2022 1 hour ago, Emporium said: BT200 also has TV volume control buttons So 2 extra programmable buttons. ya it has same button layout as the ir-200 Quote
