On my xr’s 4900 my Home Screen doesn’t change to modern view but does change to the classic and the next one, any idea ho to get the modern one to work, also are there any videos showing how to add a background image? Thanks in advance
first switch to classic. once switched to classic scroll to right and click settings, utilities, home screen, and highlight buzztv modern and click ok. you should be on modern now.
to change background click settings, BG image or change background from classic and select image from your list. if you dont have pictures in your download folder then you can download from browser in your box, via usb, or transfer remotely to your box with teamsviewer .
