Macca24 Posted September 6, 2022 Share Posted September 6, 2022 Hi, I’m a newbie to BuzzTV boxes, I have just bought the xrs4900 and am very impressed with it so far. One question I have is regarding the usb-c connection on the back of the box. It says it is for data but any drive or ssd I connect is not recognised. Should it be able to read/write to a drive connected to that port or am I completely off track with what the connection is for. I have an ssd connected in the compartment and that is working fine it’s just the usb-c connection that I am unable to get anything working on. Any help appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted September 6, 2022 Share Posted September 6, 2022 7 minutes ago, Macca24 said: Hi, I’m a newbie to BuzzTV boxes, I have just bought the xrs4900 and am very impressed with it so far. One question I have is regarding the usb-c connection on the back of the box. It says it is for data but any drive or ssd I connect is not recognised. Should it be able to read/write to a drive connected to that port or am I completely off track with what the connection is for. I have an ssd connected in the compartment and that is working fine it’s just the usb-c connection that I am unable to get anything working on. Any help appreciated, thanks. Its to be used with a PC It allows you to grab any data that is on the Hard Drive you have installed on the box. 1 1 Quote Link to comment Share on other sites More sharing options...
Macca24 Posted September 6, 2022 Author Share Posted September 6, 2022 OK thanks, so I can’t connect an external hard drive then? That’s a shame I thought that’s what the connection was for. No worries it’s still a great box. Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 6, 2022 Share Posted September 6, 2022 3 minutes ago, Macca24 said: OK thanks, so I can’t connect an external hard drive then? That’s a shame I thought that’s what the connection was for. No worries it’s still a great box. there's 3 usb ports on the side 1 Quote Link to comment Share on other sites More sharing options...
