Paul G. Posted August 23, 2022 Posted August 23, 2022 (edited) It's setup to default settings that is the home screen. Why does it go to server settings? Edited August 23, 2022 by Paul G. Quote
nbs. Posted August 23, 2022 Posted August 23, 2022 Is your service set up? If not instead of live tv it will go to server settings Quote
Emporium Posted August 23, 2022 Posted August 23, 2022 Only thing I can think of, is that BuzzTV app is set to "start Live TV at startup". And you may have had a profile (MAG or XC or M3U) which you deleted. So now upon power up, the BuzzTV app tries to launch, and since there is no profile defined, it goes to Server settings. Quote
Paul G. Posted August 23, 2022 Author Posted August 23, 2022 It is setup and did not delete any profile. It doent happen that often but when it does i am never around at home to fix. Quote
Emporium Posted August 23, 2022 Posted August 23, 2022 When you go into Live TV, it starts with your last connected service without issues ? No server popup ? When it does happen, and you press HOME on the remote, and then go into live TV, it works fine ? Quote
nbs. Posted August 24, 2022 Posted August 24, 2022 On 8/23/2022 at 11:56 PM, Paul G. said: It is setup and did not delete any profile. It doent happen that often but when it does i am never around at home to fix. Expand To fix it? Just hit live tv button Quote
Paul G. Posted August 24, 2022 Author Posted August 24, 2022 i thought there was a permanent fix for that it is for my blind brother Quote
dishuser Posted August 24, 2022 Posted August 24, 2022 On 8/24/2022 at 1:41 AM, Paul G. said: i thought there was a permanent fix for that it is for my blind brother Expand what software version does box have? 1 Quote
nbs. Posted August 24, 2022 Posted August 24, 2022 On 8/24/2022 at 1:41 AM, Paul G. said: i thought there was a permanent fix for that it is for my blind brother Expand Issue hasn't been reported before 1 Quote
Paul G. Posted August 24, 2022 Author Posted August 24, 2022 sorry had to go to work just got back it is still on buzztv 4 software version V20211108 Quote
dishuser Posted August 24, 2022 Posted August 24, 2022 On 8/24/2022 at 10:14 PM, Paul G. said: sorry had to go to work just got back it is still on buzztv 4 software version V20211108 Expand you should consider updating to buzztv 5 1 Quote
dishuser Posted August 24, 2022 Posted August 24, 2022 pm allaboutbuzz your server id and model if you want to update Quote
Paul G. Posted August 24, 2022 Author Posted August 24, 2022 (edited) I will try to update. Thank you Edited August 24, 2022 by Paul G. 1 Quote
