sea157 Posted August 13, 2022 Share Posted August 13, 2022 Do you have a code number to allow the Buzz XRS4500 to operate with a universal remote? Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 15, 2022 Share Posted August 15, 2022 On 8/13/2022 at 1:29 PM, sea157 said: Do you have a code number to allow the Buzz XRS4500 to operate with a universal remote? Our remotes are in the Harmony Database If that's what you're referring to. 1 Quote Link to comment Share on other sites More sharing options...
sea157 Posted August 15, 2022 Author Share Posted August 15, 2022 I am looking for the code number to use with a Sony sound bar remote. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 15, 2022 Share Posted August 15, 2022 1 hour ago, sea157 said: I am looking for the code number to use with a Sony sound bar remote. Which buttons are you trying to use with it? Quote Link to comment Share on other sites More sharing options...
sea157 Posted August 15, 2022 Author Share Posted August 15, 2022 Just to turn it on and off and to change channels. But if I get the code numbers it may operate almost everything the Buzz remote does. Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted August 15, 2022 Share Posted August 15, 2022 Well you can program the Buzz Remote to your Sony Sound Bar This explains how to do that We don't have the remote codes you're looking for. 2 Quote Link to comment Share on other sites More sharing options...
