Guest Ryan S Posted April 5, 2020 Share Posted April 5, 2020 How do you skip to the next/previous track using only the remote control? Using the IR-100L remote and it only has fast forward/rewind buttons however most remotes I see for BuzzTV devices don't seem to have these buttons on them forcing you to use the on screen display. Thank you in advance Quote Link to comment Share on other sites More sharing options...
nbs. Posted April 5, 2020 Share Posted April 5, 2020 you cant Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 6, 2020 Share Posted April 6, 2020 On 4/5/2020 at 2:27 AM, Guest Ryan S said: How do you skip to the next/previous track using only the remote control? Using the IR-100L remote and it only has fast forward/rewind buttons however most remotes I see for BuzzTV devices don't seem to have these buttons on them forcing you to use the on screen display. Thank you in advance Almost all of our BuzzTV remotes have the Fast Forward + Rewind Buttons. Unless am not understanding your question exactly... What next/previous track are you referring to exactly? Quote Link to comment Share on other sites More sharing options...
nbs. Posted April 6, 2020 Share Posted April 6, 2020 my understanding was he would like to skip to the next episodes.for example if watching 3 go to 4 or 5 Quote Link to comment Share on other sites More sharing options...
Ryan S Posted April 7, 2020 Share Posted April 7, 2020 8 hours ago, allaboutbuzz said: Almost all of our BuzzTV remotes have the Fast Forward + Rewind Buttons. Unless am not understanding your question exactly... What next/previous track are you referring to exactly? I am looking to skip to the next track or file clip. Not fast forward / rewind Quote Link to comment Share on other sites More sharing options...
Ryan S Posted April 7, 2020 Share Posted April 7, 2020 6 hours ago, nbs. said: my understanding was he would like to skip to the next episodes.for example if watching 3 go to 4 or 5 Correct Quote Link to comment Share on other sites More sharing options...
allaboutbuzz Posted April 7, 2020 Share Posted April 7, 2020 10 hours ago, Ryan S said: Correct Ok that makes more sense We currently don't have a feature like that Will look to adding it to the info bar with a colored button. Quote Link to comment Share on other sites More sharing options...
