MORT Posted August 1, 2022 Share Posted August 1, 2022 Hello My new Box just arrived but I am experiencing an audio problem whaich I believe is caused by the "Bluetooth". Whenever I play for example my Radio Apk and I pair it to via "Bluetooth" to my Sony Speakers the sound is nice and crisp. But when I stop the radio and change it to watch a Live TV or another IPTV apk, the sound through the paired speakers become glithcy & distorted. To fix I have to Unpair the Bluetooth hten Pair again. Is anyone having this problem ? Is there a FIX for this. Thanks Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 1, 2022 Share Posted August 1, 2022 if you just got this "box" how are you using beta software? Quote Link to comment Share on other sites More sharing options...
MORT Posted August 1, 2022 Author Share Posted August 1, 2022 Actually it is the XRS4500 MAX...but there was no Category in the dropdown menu for it, so I picked one Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 1, 2022 Share Posted August 1, 2022 4 minutes ago, MORT said: Actually it is the XRS4500 MAX...but there was no Category in the dropdown menu for it, so I picked one that's because all 3 versions of the 4500 use same software Quote Link to comment Share on other sites More sharing options...
MORT Posted August 1, 2022 Author Share Posted August 1, 2022 is it a software issue ? and is there a Fix ? Thx Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 1, 2022 Share Posted August 1, 2022 hopefully someone running older firmware might know every one I know is running beta5 Quote Link to comment Share on other sites More sharing options...
MORT Posted August 2, 2022 Author Share Posted August 2, 2022 I am just a NewBee to this stuff , How can I get a copy of this Beta 5 Firmware. More importantly, Would it run on the XRS4500 MAX to correct this audio problem ? Thx Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 2, 2022 Share Posted August 2, 2022 Pm allaboutbuzz with your mac addy Quote Link to comment Share on other sites More sharing options...
MORT Posted August 2, 2022 Author Share Posted August 2, 2022 which is the Best plat to PM - FaceBook or Instagram ? Thx Quote Link to comment Share on other sites More sharing options...
dishuser Posted August 2, 2022 Share Posted August 2, 2022 6 minutes ago, MORT said: which is the Best plat to PM - FaceBook or Instagram ? Thx right here go to home page and scroll down and on the right you will see allaboutbuzz click on his username and select message 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted August 2, 2022 Share Posted August 2, 2022 5 hours ago, MORT said: which is the Best plat to PM - FaceBook or Instagram ? Thx None of the above He is here...lol Quote Link to comment Share on other sites More sharing options...
