Flyinghigh Posted July 29, 2022 Share Posted July 29, 2022 (edited) My vidstick is freezing and out of sync. This happens on several channels. I am running the same provider on both my x5 and vidstick. The channel on my x5 is not pausing or freezing. Same VPN city/server on both devices. This is only happening on the vidstick. The vidstick also has the spinning wheel continuously on the picture at times. A restart seems to fix that. (also happens on x5) What is different about my vidstick to make it pause and get out of sync? EDIT... No external storage on either. Edited July 29, 2022 by Flyinghigh Added information Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 29, 2022 Share Posted July 29, 2022 (edited) What version is the vidstick on? Are you using same video player? Edited July 29, 2022 by nbs. Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 v20220111 Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 29, 2022 Share Posted July 29, 2022 2 minutes ago, Flyinghigh said: v20220111 Buzz version? Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 2.220111 Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 29, 2022 Share Posted July 29, 2022 15 minutes ago, Flyinghigh said: 2.220111 Hit the menu button Buzz version is at bottom Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 Gheesh, guess I am lost, uh? haha Here ya go. 5.0.653 Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 22 minutes ago, nbs. said: What version is the vidstick on? Are you using same video player? Yes I am using the internal buzztv player. Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 29, 2022 Share Posted July 29, 2022 39 minutes ago, Flyinghigh said: Yes I am using the internal buzztv player. There are two internal players You can pm allaboutbuzz with your version number and mac addy and add him to update your stick Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 3 minutes ago, nbs. said: There are two internal players You can pm allaboutbuzz with your version number and mac addy and add him to update your stick Yes, I do see a default and secondary. I am using the secondary option. I will PM buzz. Thanks nbs. Quote Link to comment Share on other sites More sharing options...
nbs. Posted July 29, 2022 Share Posted July 29, 2022 Did you try default to see of sync issue goes away? Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 13 minutes ago, nbs. said: Did you try default to see of sync issue goes away? Yeah, I just tried it again. Note to self..... don't do that again. It was much worse with the default player. Not only was it out of sync, the pic froze while audio was still playing on multiple channels. Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 Standby. PM with allaboutbuzz Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 29, 2022 Author Share Posted July 29, 2022 Well, I ended up doing a reset. This time I changed a couple settings 1 at a time. Found I can not change a couple settings, like the resolution option to best. Caused havoc with my setup. I am back up and have all my apps installed. I only changed the temp. setting, turned on TS and maybe 1 other setting. I am running well as of now. Thanks for the help allaboutbuzz and nbs. 2 Quote Link to comment Share on other sites More sharing options...
Flyinghigh Posted July 31, 2022 Author Share Posted July 31, 2022 Now for the rest of the story.... So things were running pretty good, then not so good. So I reset again. Same issue. It was confusing for me to figure out what the heck was the problem. All the help on here, and it still wouldn't work. So I got to wondering if my TV was too old? I had another TV here and was newer. I hook it up. Bang, many issues solved just like that. It appears it was not the vidstick all along. It was the darn TV. .......making note to self. 2 Quote Link to comment Share on other sites More sharing options...
