Angiesdroids Posted July 20, 2022 Posted July 20, 2022 HD5 devices, totally random and I've even seen it in live tv, pop up sayiing media not supported. VOD and Tv Series some do it some don't. Def not the provider, tried different providers, and different devices/apps and works fine. Is Mike on here?? Thanks Quote
allaboutbuzz Posted July 20, 2022 Posted July 20, 2022 2 hours ago, Angiesdroids said: HD5 devices, totally random and I've even seen it in live tv, pop up sayiing media not supported. VOD and Tv Series some do it some don't. Def not the provider, tried different providers, and different devices/apps and works fine. Is Mike on here?? Thanks If you're using XC Login In the configuration menu Change the stream type from TS to HLS Reboot the box after doing this. And the issue should be resolved. 1 Quote
