Tomshafer Posted July 18, 2022 Posted July 18, 2022 I can't get it update. Just says pending, restarted it, changed wifi, nothing. Just wondered if anyone else had that problem. Quote
allaboutbuzz Posted July 18, 2022 Posted July 18, 2022 This is an issue with Google Services Try this Go to Settings -> Apps -> select Google Play Store from list -> select Clear data and confirm it. Do same for Google play services (it's under system apps list under Apps). This should fix issue. 2 Quote
allaboutbuzz Posted July 20, 2022 Posted July 20, 2022 On 7/18/2022 at 1:04 PM, Tomshafer said: I can't get it update. Just says pending, restarted it, changed wifi, nothing. Just wondered if anyone else had that problem. Expand Any update to what I suggested to try on my post above Quote
gig63 Posted July 25, 2022 Posted July 25, 2022 I just tried 3 times the first two times in google play store i clicked on update now and it just sat there doing nothing. The third time instead of clicking update now I clicked on android system web view which took me to another screen and then clicked update and it was successful Thank you for your time Quote
Tomshafer Posted July 25, 2022 Author Posted July 25, 2022 On 7/20/2022 at 2:31 PM, allaboutbuzz said: Any update to what I suggested to try on my post above Expand Sorry I just saw this now. I'm going to try it when I get home from work today. Thanks for your help, I'll post if it works. 1 Quote
Tomshafer Posted July 25, 2022 Author Posted July 25, 2022 On 7/25/2022 at 9:12 PM, Tomshafer said: Sorry I just saw this now. I'm going to try it when I get home from work today. Thanks for your help, I'll post if it works. Expand It worked!!! All updated. Thanks again. Quote
allaboutbuzz Posted July 25, 2022 Posted July 25, 2022 On 7/25/2022 at 9:39 PM, Tomshafer said: It worked!!! All updated. Thanks again. Expand Ok great to hear that Quote
Tomshafer Posted July 25, 2022 Author Posted July 25, 2022 On 7/25/2022 at 9:39 PM, allaboutbuzz said: Ok great to hear that Expand Any news on when they're going to re-push the firmware update? Thanks Quote
