Ryu Posted July 4, 2022 Posted July 4, 2022 (edited) There are three Player options with the X5 1. Default 2. Secondary 3. External Player -- The Default and the Secondary Players have been preinstalled on the X5... with one of these Players most likely being a version of the VLC Player, as Buzz Team have in the past installed the VLC onto some of their Buzz devices. -- The External Player refers to any Player or Players that you yourself have installed since you purchased the STB An External Player may or may not work, depending on the Player and it's compatibilities. There are three different iptv connection methods with the X5 and shown below are the Player configurations. 1. MAC Server -- Live TV gives you two selections (Default and Secondary), -- TV Series and VOD give you three selections (Default and Secondary and External), with the Default and the Secondary Player both working. 2. XC API Login -- Live TV gives you two selections (Default and Secondary), -- TV Series and VOD give you three selections (Default and Secondary and External), with the Default Player working. While the Secondary Player will not work with papiao TV Series or VODs thru the XC API Login method. 3. M3U -- Live TV gives you two selections (Default and Secondary), -- TV Series and VOD give you three selections (Default and Secondary and External), with the Default Player working. While the Secondary Player will not work with papiao TV Series or VODs thru the M3U method. To access the Player selections follow the path shown below... Menu button on RCU > Settings > Configuration > LiveTV or VOD+Series Edited July 4, 2022 by Ryu Quote
dishuser Posted July 4, 2022 Posted July 4, 2022 #1.you don't give credit to OP #2.you're promoting a service Quote
