G2P Posted March 7, 2020 Posted March 7, 2020 I am having issue with VOD updates , it is 2 to 4 day old and not current episodes. for same server on other 3 Mag box has also up to date (current episodes) is there any bugs or settings i need to change (sometimes it updates after rebooting but most of the time not) I checked with service provider and according them there may be something with the box as other Mag box has no problem Please help Thanks Quote
nbs. Posted March 8, 2020 Posted March 8, 2020 send the name of your server to allaboutbuzz He will check into it I have vod on 3 servers with no issues 1 Quote
allaboutbuzz Posted March 11, 2020 Posted March 11, 2020 On 3/7/2020 at 6:32 PM, G2P said: I am having issue with VOD updates , it is 2 to 4 day old and not current episodes. for same server on other 3 Mag box has also up to date (current episodes) is there any bugs or settings i need to change (sometimes it updates after rebooting but most of the time not) I checked with service provider and according them there may be something with the box as other Mag box has no problem Please help Thanks This was fixed via PM But I will list how here If you have this issue When in VOD Press the menu button Go to configuration Scroll to the bottom and turn Server Favorites On Do a reboot and it will start to work Majority of servers require Buzz app to save favorites to an internal database on the box. While a small amount of others have it stored on their server. So we just put an on/off switch to make it work for ones with this issue. 1 Quote
