Rinny1 Posted June 23, 2022 Posted June 23, 2022 Wondering why the wifi signal weak anyone notice this..? Quote
Rinny1 Posted June 23, 2022 Author Posted June 23, 2022 Ya E2 no problems had tons of them. We’re I test the box’s I get 89 Mbps have 2 Max boxes both 12 Mbps in the same location plug my x5 in it’s 89 Mbps all on wifi Quote
dishuser Posted June 23, 2022 Posted June 23, 2022 1 hour ago, Rinny1 said: Ya E2 no problems had tons of them. We’re I test the box’s I get 89 Mbps have 2 Max boxes both 12 Mbps in the same location plug my x5 in it’s 89 Mbps all on wifi 2.4 or 5g? Quote
Rinny1 Posted June 23, 2022 Author Posted June 23, 2022 It’s worse on both boxes on 2.4g hardwired no problems!! Quote
Rinny1 Posted June 23, 2022 Author Posted June 23, 2022 Also the E2 max boxes slow !!!! For a 4 Ram the E2 faster !!! something wrong Quote
Rinny1 Posted June 25, 2022 Author Posted June 25, 2022 Update on this wifi connection the modem 75ft away moved closer 25ft away wifi connection fine looking like the Max range shorter 1 Quote
allaboutbuzz Posted June 27, 2022 Posted June 27, 2022 On 6/24/2022 at 8:15 PM, Rinny1 said: Update on this wifi connection the modem 75ft away moved closer 25ft away wifi connection fine looking like the Max range shorter All E2s use the exact same Wifi Module + 2X2 Antenna Only differences are RAM + Internal Memory 1 Quote
Rinny1 Posted June 27, 2022 Author Posted June 27, 2022 Good to know I’ll monitor it, seems fine Quote
