Observations and Questions
Tomshafer
New X5 128 owner. Very happy in general with the box. The fastest I've ever had. I've done the new update and here are a few things I've notice and a couple questions.
Internal storage when you click it still says 0B available. Gives total space correctly under storage.
Removable storage when click gives the wrong storage available. Gives total space correctly under storage.
Cannot clear cached data from internal storage under device preferences.
Time shift only works from secondary player not the internal player which actually works better in a lot of situations.
Is there anyway to add another player for live TV?
These are my observations after a few weeks. The apks all play flawlessly so far. The exceptions are a few apps that are downloaders and cleaners that don't work properly but nothing major.
I hope this is in the proper place as I am new to the Buzztv forum.
2 hours ago, Tomshafer said:
Under settings. I'll attach pics. You have to clear cache individually. Won't do it from the storage.
It looks like you formatted the USB drives as internal shared storage.
So it's trying to save apps to this instead of the actual Internal storage.
There are no apps saved to the external drive. I made that mistake earlier but figured out how to do it for recording by making it a regular drive. It doesn't show the proper space available just total space. Also you can't clear the cache. All apps are on the internal storage.
On 6/16/2022 at 8:02 PM, allaboutbuzz said:
TS only works on Secondary as its built into the player
Default is VLC which doesn't have TS available.
As for the storage questions, where are you checking this exactly?
You also can't clear any drives that you plug in, they all say not connected but you can't clear them.
