putski Posted June 12, 2022 Share Posted June 12, 2022 my xrs4900 is stuck in reboot mode, i can't get into menu nor the settings it just keeps rebooting over and over... any suggestions as to fix this issue? Thanks for any Help Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 12, 2022 Share Posted June 12, 2022 58 minutes ago, putski said: my xrs4900 is stuck in reboot mode, i can't get into menu nor the settings it just keeps rebooting over and over... any suggestions as to fix this issue? Thanks for any Help pin reset 3 Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 12, 2022 Share Posted June 12, 2022 2 Quote Link to comment Share on other sites More sharing options...
putski Posted June 13, 2022 Author Share Posted June 13, 2022 Well I have tried this like 8 times over and over and still reboots not sure what the heck is going on... Quote Link to comment Share on other sites More sharing options...
dishuser Posted June 13, 2022 Share Posted June 13, 2022 55 minutes ago, putski said: Well I have tried this like 8 times over and over and still reboots not sure what the heck is going on... when in recovery screen are you selecting wipe data? are you using the power adapter that came with it? cause the 4900 uses 12 v 1 Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 13, 2022 Share Posted June 13, 2022 9 hours ago, putski said: Well I have tried this like 8 times over and over and still reboots not sure what the heck is going on... Are you getting to the recovery screen? Quote Link to comment Share on other sites More sharing options...
Pat Traaseth Posted June 13, 2022 Share Posted June 13, 2022 yes on the wipe the data clear and yes on the correct power adapter Quote Link to comment Share on other sites More sharing options...
Pat Traaseth Posted June 13, 2022 Share Posted June 13, 2022 yes I can get into the recovery screen Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 13, 2022 Share Posted June 13, 2022 And as dishuser asked are you scrolling to wipe data? 1 Quote Link to comment Share on other sites More sharing options...
Pat Traaseth Posted June 13, 2022 Share Posted June 13, 2022 9 minutes ago, nbs. said: And as dishuser asked are you scrolling to wipe data? I will have to check when I get back home.. I did just as the video showed. Should be back home in a couple hours. Quote Link to comment Share on other sites More sharing options...
Pat Traaseth Posted June 13, 2022 Share Posted June 13, 2022 yes i can wipe data / factory reset some times it reboots before letting me get the setup done. i have tried it many times.. but I'm going to try again. Quote Link to comment Share on other sites More sharing options...
Pat Traaseth Posted June 17, 2022 Share Posted June 17, 2022 is there any thing else I can try to bring this box back to life? Quote Link to comment Share on other sites More sharing options...
nbs. Posted June 17, 2022 Share Posted June 17, 2022 You can load a file from recovery screen Worth a shot Ask allaboutbuzz for a link to the file 2 Quote Link to comment Share on other sites More sharing options...
