Raidersam67 Posted April 30, 2022 Posted April 30, 2022 can you change the background on a XRS4500 running buzz4?...i just purchased the box and cannot find where to add/change backgrounds.... Quote
Ryu Posted April 30, 2022 Posted April 30, 2022 have you checked in My Apps > Files > Images. I think pictures saved in images will give you an option to add/change background. 1 Quote
dishuser Posted April 30, 2022 Posted April 30, 2022 5 hours ago, Raidersam67 said: can you change the background on a XRS4500 running buzz4?...i just purchased the box and cannot find where to add/change backgrounds.... you need to use media player or media player 2 settings/change background 1 1 Quote
Raidersam67 Posted May 7, 2022 Author Posted May 7, 2022 On 4/30/2022 at 5:21 PM, dishuser said: so how did you make out? i got backgrounds to work...but only on media player and media player 2.... Quote
dishuser Posted May 7, 2022 Posted May 7, 2022 7 hours ago, Raidersam67 said: i got backgrounds to work...but only on media player and media player 2.... that's because you don't have buzztv 5 1 Quote
