Macman_ca Posted 4 hours ago Posted 4 hours ago Last couple of nights I haven't been able to see the TV guide. When I hit guide on the buzz remote it kicks me to my server settings. I select the server and it shows it refreshing etc then goes to the guide, but no info. can't see any shows ahead or behind? Doesnt matter which server I use. same issue. I use the 3 line button on the remote to refresh and nothing changes. Goes back to single channel. Thoughts? Quote
Emporium Posted 3 hours ago Posted 3 hours ago MAC or XC type connection ? I know that for MAC type connections there is a new version coming soon which includes "Fixed EPG Loading on MAC for Some Servers". Obviously it depends on the server however. For XC, I have not had an issue (at least with the 2 servers I mainly use - and you know one of the servers at least ). Maybe something has glitched ? I'm assuming you went into menu and "cleared EPG" to force a reset ? Try changing EPG source (server vs xml) ? Is it just in "guide" view or even in channel list view (where you see what's playing and a few more) ? backup, clear storage on buzztv 6 app and then restore maybe ? Quote
Macman_ca Posted 3 hours ago Author Posted 3 hours ago I had the same issue with both servers. One is Mac and one is XC. I will try the setting suggestion and see. Thank you! 1 Quote
Macman_ca Posted 1 hour ago Author Posted 1 hour ago I had the same issue with both servers. One is Mac and one is XC. I tried your suggestions no luck. That one app with one server I can see the guide. So it seems to be in buzz tv part. Both servers have the same issue. I go to guide, no information. It kicks me to the server connect info box and both are showing. Connected. Viscious loop. Quote
Macman_ca Posted 25 minutes ago Author Posted 25 minutes ago I managed to get one of my servers to load. The XC server shows the proper guide. But the MAC server nope. Go figure. Quote
