skidoouky Posted January 17, 2022 Posted January 17, 2022 I log onto api with all credentials, it connects i get all guided and channels but nothing comes on, i get the wheel spinning in the middle of the screen? if i use an app iptv gotv to log on everything works with that app only, but no picture with the standard buzz tv live tv shorcut? Quote
dishuser Posted January 18, 2022 Posted January 18, 2022 2 hours ago, skidoouky said: I log onto api with all credentials, it connects i get all guided and channels but nothing comes on, i get the wheel spinning in the middle of the screen? if i use an app iptv gotv to log on everything works with that app only, but no picture with the standard buzz tv live tv shorcut? try the other player 1 Quote
Nelutz Posted January 18, 2022 Posted January 18, 2022 4 hours ago, skidoouky said: I log onto api with all credentials, it connects i get all guided and channels but nothing comes on, i get the wheel spinning in the middle of the screen? if i use an app iptv gotv to log on everything works with that app only, but no picture with the standard buzz tv live tv shorcut? Uif you did the update ,than probably you using the secondary player from the previous set-up, main player is better option now Quote
dishuser Posted January 18, 2022 Posted January 18, 2022 12 minutes ago, Nelutz said: Uif you did the update ,than probably you using the secondary player from the previous set-up, main player is better option now now you know why they provide more than one player...lol 1 Quote
skidoouky Posted January 18, 2022 Author Posted January 18, 2022 i rest the box and now it updated to buzz 5.0 automatically for some reason and i re inputed info and works normally again 1 Quote
