el mahdi Posted September 21, 2025 Posted September 21, 2025 Hello, days ago I bought the Powerstation 6 Unlimited. I have a problem with LiveTV, I can't exit to go to YouTube. I hear the audio of both programs, Live TV and YouTube. I've reset it twice, VOD and series work fine. There's another thing, the "download VOD & series" option from Buzz 5 is no longer on the 6. I hope for a software update, and thank you. Quote
nbs. Posted September 21, 2025 Posted September 21, 2025 You could always go to home page then to YouTube. Could you clarify that the download is there on the p6 when using buzz 5? Post your firmware and software version. 1 Quote
dishuser Posted September 21, 2025 Posted September 21, 2025 press 5 to exit live tv when on home screen Quote
dishuser Posted September 21, 2025 Posted September 21, 2025 download option is only available on buzztv 5 1 Quote
allaboutbuzz Posted September 22, 2025 Posted September 22, 2025 20 hours ago, dishuser said: download option is only available on buzztv 5 Its on the road map for Buzz 6 No set dates currently 3 Quote
