Richard Demitra Posted September 12 Posted September 12 (edited) Hello BuzzTV Support, I own a BuzzTV Powerstation 6 and I am experiencing an issue with audio passthrough. Whenever I use Dolby Digital, Dolby Digital+, Dolby TrueHD, or Dolby Atmos passthrough, the sound briefly cuts out whenever I press any button on the remote (for example, when showing “Info” about the current video, adjusting volume, or opening any on-screen display). I would like to use my AVR (Denon/Marantz) to decode the audio formats directly, but these constant dropouts make Atmos and other passthrough formats unusable. Could you please advise if this is: a known firmware issue, a setting I may have overlooked (RAW vs IEC passthrough, audio mixing, etc.), or if there is an upcoming update that will fix this? Thank you for your support. Edited September 12 by Richard Demitra Quote
Woody Posted September 12 Posted September 12 I use my tv to decode have the hdmi input set to bitsream. Have not had any drop out issues at all. And i have lg 4.1 ch sound bar im using for sound. 3 Quote
T28 Posted September 16 Posted September 16 I can duplicate what Richard says but only when I am streaming 4k video. If I drop down to FHD or lower the audio drop outs go away. i am running a 7.1 system through a Trinnov Altitude16 Quote
dishuser Posted September 16 Posted September 16 turn decode on because most services only offer 5.1 for fhd Quote
allaboutbuzz Posted September 17 Posted September 17 On 9/12/2025 at 4:52 AM, Richard Demitra said: Hello BuzzTV Support, I own a BuzzTV Powerstation 6 and I am experiencing an issue with audio passthrough. Whenever I use Dolby Digital, Dolby Digital+, Dolby TrueHD, or Dolby Atmos passthrough, the sound briefly cuts out whenever I press any button on the remote (for example, when showing “Info” about the current video, adjusting volume, or opening any on-screen display). I would like to use my AVR (Denon/Marantz) to decode the audio formats directly, but these constant dropouts make Atmos and other passthrough formats unusable. Could you please advise if this is: a known firmware issue, a setting I may have overlooked (RAW vs IEC passthrough, audio mixing, etc.), or if there is an upcoming update that will fix this? Thank you for your support. Are you using the HDMI ARC port to the box? And what version of HDMI is your receiver? If you do not have HDMI 2.1 on receiver 4k and Atmos will exceed bandwidth basically. 1 Quote
T28 Posted September 19 Posted September 19 (edited) On 9/15/2025 at 11:36 PM, dishuser said: turn decode on because most services only offer 5.1 for fhd Makes sense. Sorry but where would I find the decode switch? Nevermind, found it. thanks Edited September 19 by T28 1 Quote
T28 Posted September 19 Posted September 19 On 9/15/2025 at 11:36 PM, dishuser said: turn decode on because most services only offer 5.1 for fhd Bummer but switching from hdmi to decode didn’t have any apparent effect. Audio still drops out during button press when in 4k mode. (Easy fix is not to press buttons while watching 4k, lol) 1 Quote
Emporium Posted September 19 Posted September 19 Maybe try to change to a better quality HDMI cable ? If it is not HDMI 2.1 compliant, bandwidth would be restricted as aab mentioned above. It would be fine in lower resolutions, but not possibly not in 4k. Quote
dishuser Posted September 19 Posted September 19 32 minutes ago, Emporium said: Maybe try to change to a better quality HDMI cable ? If it is not HDMI 2.1 compliant, bandwidth would be restricted as aab mentioned above. It would be fine in lower resolutions, but not possibly not in 4k. the powerstation comes with an 8k (2.1) cable 3 Quote
Emporium Posted September 19 Posted September 19 (edited) 1 hour ago, dishuser said: the powerstation comes with an 8k (2.1) cable True, but it can still be damaged/defect (it happens). And was never mentioned that they were actually using the original cable which came with the Powerstation. Worth trying another one. Edited September 19 by Emporium Quote
ManFromRI Posted September 21 Posted September 21 On 9/12/2025 at 4:52 AM, Richard Demitra said: Hello BuzzTV Support, I own a BuzzTV Powerstation 6 and I am experiencing an issue with audio passthrough. Whenever I use Dolby Digital, Dolby Digital+, Dolby TrueHD, or Dolby Atmos passthrough, the sound briefly cuts out whenever I press any button on the remote (for example, when showing “Info” about the current video, adjusting volume, or opening any on-screen display). I would like to use my AVR (Denon/Marantz) to decode the audio formats directly, but these constant dropouts make Atmos and other passthrough formats unusable. Could you please advise if this is: a known firmware issue, a setting I may have overlooked (RAW vs IEC passthrough, audio mixing, etc.), or if there is an upcoming update that will fix this? Thank you for your support. Ive had this same exact problem as well. Quote
mark gower Posted Monday at 08:07 PM Posted Monday at 08:07 PM I only managed to get HBO max to work with pass through in advanced system sound settings I have this set to manually select formats this worked for me. Disney plus didn’t work Quote
