buzywoman Posted September 5, 2025 Posted September 5, 2025 hello with xrs-4900 and xrs-4500 screenshot is easy by power button (shutdown, reboot or screenshot), but on p6 unlimited y not find method for take a screenshot. tanks Quote
buzywoman Posted September 5, 2025 Author Posted September 5, 2025 23 minutes ago, dishuser said: there isn't one ok, y try to map button to screenshot function . tanks Quote
dishuser Posted September 5, 2025 Posted September 5, 2025 9 hours ago, buzywoman said: ok, y try to map button to screenshot function . tanks a function that doesn't exist? good luck Quote
buzywoman Posted September 5, 2025 Author Posted September 5, 2025 9 hours ago, dishuser said: a function that doesn't exist? good luck y have paired a usb mini keyboard Ipazzport and function + f7 work for printscreen Quote
dishuser Posted September 5, 2025 Posted September 5, 2025 and where does it save to? can you use it as background? Quote
buzywoman Posted September 5, 2025 Author Posted September 5, 2025 work on kodi and other apps, but for buzztv apps work randomly. save in internal sd card/pictures/screenshots Quote
buzywoman Posted September 9, 2025 Author Posted September 9, 2025 (edited) problem solved with this remapper app mapped long press to home button Edited September 9, 2025 by allaboutbuzz Cant post links Quote
Emporium Posted September 9, 2025 Posted September 9, 2025 No offence, and I am glad you find a workaround. But honestly, why is it such a "very important function". I have NEVER had to take a screenshot of any of my buzz boxes. Have no clue why you would need to, other than occasionally maybe having to send a screen snapshot to BuzzTV for reporting bugs. And in those cases, a quick snapshot with phone camera is sufficient. I do occasionally need to capture a short video to provide small tutorials to some of my elderly friends, but I ended up just getting a small cheap USB video capture device from amazon for short video tutorials. Quote
buzywoman Posted September 9, 2025 Author Posted September 9, 2025 19 minutes ago, nbs. said: Please don't post live links ok, sorry, but y don't have a option for edit post, please delete post Quote
buzywoman Posted September 9, 2025 Author Posted September 9, 2025 (edited) 13 minutes ago, Emporium said: No offence, and I am glad you find a workaround. But honestly, why is it such a "very important function". I have NEVER had to take a screenshot of any of my buzz boxes. Have no clue why you would need to, other than occasionally maybe having to send a screen snapshot to BuzzTV for reporting bugs. And in those cases, a quick snapshot with phone camera is sufficient. I do occasionally need to capture a short video to provide small tutorials to some of my elderly friends, but I ended up just getting a small cheap USB video capture device from amazon for short video tutorials. for save a app setting , config for my memory, and tv news, I am old person and my memory is not same as young. Edited September 9, 2025 by buzywoman 1 Quote
buzywoman Posted September 9, 2025 Author Posted September 9, 2025 3 minutes ago, buzywoman said: ok, sorry, but y don't have a option for edit post, please delete post after a time edit function disapear Quote
