William Wood Posted June 30 Posted June 30 Anyone having freezing problems I have tried everything I did factory reset the other day it worked great for two days now back to freezing about every 5-10 minutes .I have 2 suppliers and both freeze I also have a T2 box which is about 5 years old and it freezes also but not like the SS maybe once in a while So its not the internet Its hard wired cat 6 wire,I tried diff. players,using Mac servers,clear cashe,re set everythig the only thing that helped was the factory reset, Need help Quote
William Wood Posted June 30 Author Posted June 30 No external player . Tried a vpn in Florida but the box just quit working had to take it off ,had surf shark. I am back in Canada but had same problems in Florida I have Bell And Spectrum in the states. The box is only 7 months old  Quote
Emporium Posted June 30 Posted June 30 Have you tried rebooting your modem and router ?  OK, I know it sounds like a long shot, but it has happened to me on at least 3 different occasions, so I will put it out there. Do you have any Dlink switches (or router) on your network. If so, do you have alternatives to replace them ?  In at least 3 cases I had, myself and at 2 buddies places, simply the existence of a DLINK switch on our network cause all sorts of strange behaviors which I could not explain. Even if it had nothing else connected to it, when they start to fail, they seem to create chaos on a network even on devices not directly connected to these switches.  Swapped out all dlink equipment (with netgear or even tplink) and all the problems went away. In one of my buddies cases, it was a brand new dlink router he had purchased (we swapped it with an old asus one and issues solved). Don't know what the dlink equipment was doing or what would trigger it, but I have since promised myself that no more dlink junk in any of my installations.  In my case, the dlink switch was on my test bench (where I often build/test machines), with no machines connected to it, just the main network line coming from the main switch. Since it had no devices connected to it, I completely discounted it initially, and took me quite a while to diagnose the issue. Actually took a few days - until I decided to go down to basics and disconnect all devices and run single line only direct from buzz box to router - and then work my way back up. Quote
William Wood Posted June 30 Author Posted June 30 No just my modem I just called Bell they are going to send me another modem but I dont think thats the problem Because I have a t2 box and I get some freezing but not like my ss box its almost constant when its start Quote
nbs. Posted June 30 Posted June 30 15 minutes ago, William Wood said: No external player . Tried a vpn in Florida but the box just quit working had to take it off ,had surf shark. I am back in Canada but had same problems in Florida I have Bell And Spectrum in the states. The box is only 7 months old  Then install vlc on your buzz and use external player to see if it still freezes Quote
Emporium Posted June 30 Posted June 30 The T2 may be allocating a slightly larger cache on it's internal player, which will just mask network glitches and be a little more immune to freezing because of that. But still doesn't change the underlying issue. The fact that the T2 freezes also, tells me there is either some issue with your internet, or something with the servers.   2 Quote
