Just now, Raees said:
Yes
Its likely a hls stream which cant be downloaded Its difficult determining some hls streams Buzz are working on the messaging
But just to confirm..its wrking very nice today..my wifey not so much but my 10 yr old love the new update. He loves the fact that the episodes looks and feels like youtube..very user friendly.
  • 3 weeks later...
Everytime i turn the tv off,box will go in sleep mode automatically..thats perfect. But when i turn the tv on..the box will not turn on automatically. I would allways have to turn it on using buzz remote.
plz let me know if there is any fix for this.
home page/settings/advanced settings
what is powerkey definition set to?
  • Thanks 1
40 minutes ago, nbs. said:
Try setting it to shutdown
Ok set to shutdown but still wont turn on when turn the tv on. Only shuts off when turn tv off.
press power button and hold
now you get 3 options
On 1/31/2022 at 5:02 AM, Maestro701 said:
Your TV should also have the HDMI cec option. If it does you must enable it too. Hope it works for you
Its enable in tv. The issue is..it only turns off the box when i turn off tv..it would not turn on automatically when i turn the tv on which i really would like it to.
OK, it's the turning on of the box you need when tv is turned on.
It's not working for me either. I know it used to work way back on the 3000 series but haven't used it since. Will play around with it some more and keep you posted.
  • Thanks 1
