stdly Posted March 9, 2025 Posted March 9, 2025 When I set a reminder or record on a channel say sports then my guide changes to the sports category. I reset to all and close it reopen the guide and it is set to sports again until the reminder or recording is done. Is there a way to keep the guide on all? Quote
stdly Posted March 9, 2025 Author Posted March 9, 2025 Thanks sorry about that, I have two boxes that do the same a BuzzTV X5 C and a BuzzTV XR4500 both are up to date I believe. XR4500 Firmware V20220919 IPTV Version 5.0.946 X5 Firmware V20240918 IPTV Version 5.0.946 Quote
nbs. Posted March 10, 2025 Posted March 10, 2025 I find that unless I move around in a group it will default to the last group when I open up guide 3 Quote
stdly Posted March 10, 2025 Author Posted March 10, 2025 Thanks again yes if I choose a different channel in the all category it will hold the choice. Quote
allaboutbuzz Posted March 10, 2025 Posted March 10, 2025 2 minutes ago, stdly said: Thanks again yes if I choose a different channel in the all category it will hold the choice. Yes that is the way its designed 3 Quote
