TonyC Posted February 21, 2025 Posted February 21, 2025 Hi, since the last update, i am unable to turn the P6 off, from the remote. Does anyone know how to remedy this issue. Thanks Quote
TonyC Posted February 21, 2025 Author Posted February 21, 2025 It wouldn't turn off from the button at the front either. Quote
TonyC Posted February 21, 2025 Author Posted February 21, 2025 It's paired with the tv, the tv remote switches everything off. How would that work if i bought a new tv? Quote
Ryu Posted February 21, 2025 Posted February 21, 2025 you can program buzz remote to your tv and can turn off with it. did you check manual? Quote
dishuser Posted February 21, 2025 Posted February 21, 2025 7 hours ago, TonyC said: Hi, since the last update, i am unable to turn the P6 off, from the remote. Does anyone know how to remedy this issue. Thanks are you sure you're in the correct section this time? turn cec on 1 Quote
TonyC Posted February 21, 2025 Author Posted February 21, 2025 Turned CEC off, now it goes off from the remote. Thanks Everyone for your help and input Quote
