Maestro701 Posted January 28 Posted January 28 Hey guys, rolled over on the remote last night and the screen to pair remote came up. Before I knew it it had disappeared and I noticed the remote is not paired. I tried to pair it but it's not happening. The device sees it and I click to pair but nothing happens. Quote
Emporium Posted January 28 Posted January 28 Assuming you selected Pair new device, and then put the remote into pairing mode (pressing OK and VOL- for 3 seconds till light starts flashing) ? Manual for BT-250 is here, and pairing is Step 7. https://buzztv.com/wp-content/uploads/2023/01/Classic_manual-v1_MOBILE.pdf Try power cycling the machine ? And/or turning BT off then on again ? 3 Quote
Maestro701 Posted January 28 Author Posted January 28 1 hour ago, Emporium said: Assuming you selected Pair new device, and then put the remote into pairing mode (pressing OK and VOL- for 3 seconds till light starts flashing) ? Manual for BT-250 is here, and pairing is Step 7. https://buzztv.com/wp-content/uploads/2023/01/Classic_manual-v1_MOBILE.pdf Try power cycling the machine ? And/or turning BT off then on again ? I did all that, yeah I have the manual from before but the remote control screen is not coming up Quote
Maestro701 Posted January 28 Author Posted January 28 Came home just now, add device and it paired just like that. Thanks for your assistance 3 Quote
Maestro701 Posted January 29 Author Posted January 29 Interesting to find out what "shortcut" I might have pressed to unpair the remote. Maybe it's the same one that pairs it. Won't be home until a few hours but if one of you guys can try it would be appreciated. Quote
dishuser Posted January 29 Posted January 29 7 hours ago, Maestro701 said: Interesting to find out what "shortcut" I might have pressed to unpair the remote. Maybe it's the same one that pairs it. Won't be home until a few hours but if one of you guys can try it would be appreciated. long press info button 3 1 Quote
pugsycan Posted January 29 Posted January 29 6 hours ago, Maestro701 said: Interesting to find out what "shortcut" I might have pressed to unpair the remote. Maybe it's the same one that pairs it. Won't be home until a few hours but if one of you guys can try it would be appreciated. OK this may not be even close But what I think happened is when you sat on the remote you hit a bunch of buttons and confused it or the stb and it just took abit for it to recover 1 Quote
Emporium Posted January 29 Posted January 29 15 minutes ago, dishuser said: long press info button Oh wow. All this time I never even realized long press of info button would delete a paired remote I just tried it on my X5.. I have by BT400 paired to it, and a BT250. Long press info once on my bt250, and it deleted the bt400 (probably since it was at the bottom of the list and/or added last). Long press a second time and it deletes the BT250. I have probably done that a few times without realizing it, since the info button is just under the "last channel" button which I often long press Thnx 2 Quote
Maestro701 Posted January 29 Author Posted January 29 4 hours ago, pugsycan said: OK this may not be even close But what I think happened is when you sat on the remote you hit a bunch of buttons and confused it or the stb and it just took abit for it to recover You're crazy mann Quote
Maestro701 Posted January 29 Author Posted January 29 4 hours ago, dishuser said: long press info button Thanks for the info DU Quote
