Hoping for some help. The bottom buttons on my remote are not working. None of the numbers work or the coloured buttons across the bottom.
am I doing something wrong?
When you try to press the buttons does LED in the top center light up ?
I know it is  long shot, but it happened to me once when my wife dropped a remote, so check to see if the remote has ever so slightly split apart on the bottom end (which affected the membrane contact to the board below).  Try to squeeze the remote closed where the Buzz logo is (ie: squeeze between the buzz logo and the battery cover on the back).
Maybe try one other set of batteries, just in case it is bad luck and you got some duds.
If no LED, batteries are good, and it is squeezed tight shut, there is not much else to a remote.  I'd say you possibly got a defective remote 😞
  • Thanks 1
