Arq - 100 does it work with GTV
it may work but most of the keys won't function properly. for example, if you press setting, it may or may not open setting or might open something else
  • 1 month later...
On 12/27/2021 at 1:03 PM, Quicktiger said:
has anyone tested arq-100 to see if it will work with GTV ?
the standard buttons will work such as D-Pad and Keyboard. Power button and all the buzztv shortcut buttons will not work
