Donna clarke Posted September 23, 2024 Posted September 23, 2024 I purchased Buzz TV E5 and an iptv subscription. When I press the "series " button on the remote it then shows me three headings: All Series, Favourites and Recently Watched. Everything is empty. Should this be. Quote
Donna clarke Posted September 23, 2024 Author Posted September 23, 2024 1 minute ago, nbs. said: What happens when you press vod? It does have shows Quote
nbs. Posted September 23, 2024 Posted September 23, 2024 Any chance the tv series are in there? 1 Quote
nbs. Posted September 23, 2024 Posted September 23, 2024 You would have to contact your service Quote
Emporium Posted September 23, 2024 Posted September 23, 2024 Some services don't distinguish between TV series and VOD, they just consider them the same. So in some cases, you'll just have to live with that Quote
Donna clarke Posted September 23, 2024 Author Posted September 23, 2024 Does this mean they are just all mixed in with my channels Quote
dishuser Posted September 23, 2024 Posted September 23, 2024 9 minutes ago, Emporium said: All mixed in with your VOD. they could have their own category in vod Quote
Emporium Posted September 23, 2024 Posted September 23, 2024 EDIT: My BAD, I for some reason read your first reply as "IT APPEARS SO" not "it does NOT appear so". But you should check with your provider like initially mentioned by nbs. Quote
