Bel Ma Posted September 4 Share Posted September 4 J ai un probleme avec mes telecommandes buzztv. j ai le buzztv xrs 4900, et je voudrais une telecommande air mouse. j en ai essayer 2-3 dont ARQ-200. ARQ-250 . ARQ-100 et mon probleme c est que les batteries sont morte apres 3-4 semaines . j ai beau changer les batteries de bonne qualite et rien ne fait. Toujours la meme chose,les batteries tombe toujour mortes. Je ne sait plus quoi faire. Quote Link to comment Share on other sites More sharing options...
nbs. Posted September 4 Share Posted September 4 Buy rechargeable batteties 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 4 Share Posted September 4 and learn where the buttons are so you don't need backlight 1 Quote Link to comment Share on other sites More sharing options...
Emporium Posted September 4 Share Posted September 4 I tried ages ago to use rechargeable, but the 1.2V vs 1.5V makes them not last as long either. Sure you can just swap them in/out with another set of rechargeables and costs close to nothing, but it can be annoying. Backlight can be a killer. With rechargeable, they fade super fast. I really like the BT200 for the super easy shortcut to turn backlight on/off without even needing to see the remote. Long press bottom rightmost bottom button and it toggles.. It was genius Kill the backlight and batteries last for ages, especially if you use quality batteries (Duracell or Energizer - like buzz includes ). 1 Quote Link to comment Share on other sites More sharing options...
dishuser Posted September 4 Share Posted September 4 my bt 200 batteries lasts a year per charge the bunny just goes on and on...lol 1 Quote Link to comment Share on other sites More sharing options...
Bel Ma Posted September 5 Author Share Posted September 5 OK je vais essayer des pile rechargable et je vais voir 2 Quote Link to comment Share on other sites More sharing options...
